Шаринг на ресиверах Yu-Ma-Tu и Globo
Standutz
СообщениеДобавлено: Ср Июл 12, 2006 22:54    Заголовок сообщения: Шаринг на ресиверах Yu-Ma-Tu и Globo Ответить с цитатой
По карт шарингу, у турков для Yu-Ma-Tu и Globo, началась интересная активность, появились прошивки, и по-моему прога для шаринга, все в одном месте http://www.uydu-soft.com/?page_id=6
На другом сайте, http://www.turkeyforum.com/satforum/showthread.php?t=207695&page=6, лежит описание инсталяции и как всем этим пользоваться, вот текст этой информации без картинок. По делам работы не смогу этим позаниматься, в течении трех недель, ну а по-моему это интересно.
Please, I do not speak turkish, is posssible to someone explain, how this İnternet Share PC için 1.0.0 loder works?
hands the advants of this new funcionlity.
I have install the program in reveiver and in PC, but i can't do anythig.
One of the resions is because im not finding in the receiver the menu to do the sharing thing.
Thanks, for your anthertinding am my poor english.
Hi, I am poor in English too, so I think that I am the perfect candidate to explain for you how it works, and there are the steps and there are photos for it:
1- First, you must open your receiver and be in the internet, and make sure that there is a cable between the computer and the receiver
2- Install the program and you well see a message says "Don't allow to copy and give serial number to anyone You cann't watching channels with this", now press ok, then press "finish" the program will start and you well see another message just press ok and return to the receiver
3- In the receiver stand on the "Action" channel in the Hotbird and press Menu and from it choose installation from it choose smart card then press on card share in it choose the last one "Xshare", now go to the first option in it " Serial Number Verify " and press ok, then press ok another time and wait until you see the message " S/N Verify Success", now press exit and go to the channel and it will begin in just seconds
4 - But for sad it will last just for approximately five minutes and the program will stop and you will see this message " Somebody using same id so you cann't use this" and when you press ok it closes, if you want to use the program for another five just open it again, and again, and again ….
This is the soft you should use
I wish that I and my bad English helped you
Yours
Essam from Egypt
JekSatUA
СообщениеДобавлено: Сб Июл 15, 2006 0:09    Заголовок сообщения: Re: Шаринг на ресиверах Yu-Ma-Tu и Globo Ответить с цитатой
А где можно скачать эту прогу для шаринга????? Не подскажешь?
Standutz
СообщениеДобавлено: Сб Июл 15, 2006 22:39    Заголовок сообщения: Ответить с цитатой
И прошивки и прога для шаринга нходяться здесь http://www.uydu-soft.com/?page_id=6, более поздняя прошивка от Трумана http://www.uydu-soft.com/?page_id=9 и ДСН http://www.uydu-soft.com/?page_id=41.
Насколько разобрался рассказваю:
1. Подключается к РС тюнер, и РС должен иметь выход в Инет.
2. После соединения по Инету на тюнере устанвливаешь станцию с ХотБерда, я пытался открыть М6, запускашь прогу шаринга, она связывается с шаринг центром ДСН (а дальше у меня грабли, турецкого я не знаю, нутром понимаю, что надо регится, и как понимаю за деньги, хотя бы родной "инглиш"?! Sad ) Вот на этом я встал! Sad
