Help: express am1
braluca
СообщениеДобавлено: Пн Сен 10, 2007 13:39    Заголовок сообщения: Help: express am1 Ответить с цитатой
Privet!
I am Italian (living in Milan), sorry I do not speak Russian.
I am interested in receiving Express AM1 40 east.
I have a 120 cm dish on the roof and a HUMAX 2000 HDCI receiver.
Till now I receive only Uzbekistan TV in Ku band. Nothing else. Also at roof side no other transpoder of the satellite I can see at spectrum analyzer.
I would like to receive Russian channel in mpeg4. I and antenna men I payed have no idea why no signal for Russian transponder.
Do you confirm me that transponder are at 10967 and 10994 with FEC 3/4 and Symbol Rate 20000 as written at www.rscc.ru?
Have you got any idea for help me in receiving those Russian channel.
Please help me!
Spassibo
/\yka
СообщениеДобавлено: Пн Сен 10, 2007 14:06    Заголовок сообщения: Re: Help: express am1 Ответить с цитатой
braluca писал(а):
Privet!
Please help me!
Spassibo
/\yka
Yes this is right parameters. Try dish with bigger size . I think minimum 150 sm.
Buona fortuna!
СообщениеДобавлено: Пн Сен 10, 2007 14:12    Заголовок сообщения: Ответить с цитатой
Parameters are correct.
http://www.lyngsat.com/eam1.html
The signal on 10967 and 10994 is quite weak (much weaker than TV Uzbekistan), but 120cm should be enough in Italy. Check your dish. Maybe you need a larger one, but the signal is there for sure.
urodispanii
СообщениеДобавлено: Пн Сен 10, 2007 16:36    Заголовок сообщения: Ответить с цитатой
Now i understood why i watch uzbekistan tv and couldn!t watch russian tv channels in am 1.fortunatelly they are others satellites like Hotbird,Sirius 2 and Express am 22 to watchin Russian tv channels Wink
я по националности испанец но по сердце ярусский украинец и белорусь.мне нравиться говорить по русский мені дуже подовоаетьс ярозмовлать по укрінською мяне бельмі падабазться рассмаувлаць па бзларуську ура ваша страна!
braluca
СообщениеДобавлено: Вт Сен 11, 2007 13:34    Заголовок сообщения: Ответить с цитатой
could you please tell me your QTH and dish dimension?
Just for comparing.
I also have a fixed for Hotbird so at least I can receive those channels.
But top is Express AM1.
urodispanii
СообщениеДобавлено: Вт Сен 11, 2007 16:26    Заголовок сообщения: Ответить с цитатой
Don!t worry my dish is small is only 80 cm and live on north Spain ,you have much more possibilities to receive express am 1 than me,bella fortuna amico italiano Very Happy Wink
braluca
СообщениеДобавлено: Ср Сен 12, 2007 13:06    Заголовок сообщения: Ответить с цитатой
muchas grazias drug,
uzbekistan is ok but other TP are mission impossible!
urodispanii
СообщениеДобавлено: Ср Сен 12, 2007 18:03    Заголовок сообщения: Ответить с цитатой
ma a satelitte hotbird ha molti canali russos ,bella fortuna italia e tutti il migliore per voi Wink
ttalex
СообщениеДобавлено: Пт Сен 14, 2007 16:40    Заголовок сообщения: Ответить с цитатой
Braluca,
In addition to Uzbekistan TV you can probably receive also SpaceTV Azerbaijan at 11159V 3333 3/4.
If you cannot see 11159V then you need to align your dish better, otherwise no chances to see MPEG4 at all.
I can receive MPEG4 on 1m20 ChannelMaster dish with Inverto Pro IDLP-40US Lnb and Homecast HS 5101 HDTV receiver, but the signal is quite low (10995V is a bit stronger so try this one first). I am in Brussels so in Milan (I think) you should have stronger signal.
Best regards,
Alexander
Посмотреть профиль Отправить личное сообщение Посетить сайт автора AIM Address Yahoo Messenger MSN Messenger ICQ Number
braluca
СообщениеДобавлено: Сб Сен 15, 2007 10:49    Заголовок сообщения: Ответить с цитатой
yes drug,
pervey, RTR, sport, vesti, music box, ru tv, rbk,...... no problem for them
but only express am1 let stay my wife like in Russia because broadcasts all channels that she watches in Petrick.
W Taquilla
hasta lluego
braluca
СообщениеДобавлено: Сб Сен 15, 2007 11:51    Заголовок сообщения: Ответить с цитатой
no space tv for me Crying or Very sad
my respect, you have a channel master dish!!!!
braluca
СообщениеДобавлено: Сб Ноя 03, 2007 1:33    Заголовок сообщения: success Ответить с цитатой
And finally today with dish Gibertini 125 I receive RSCC bouquets on Express AM1 and also Space TV
Thanks to everybody
ttalex
СообщениеДобавлено: Пн Ноя 05, 2007 2:01    Заголовок сообщения: Re: success Ответить с цитатой
Congratulations!!! The signal was much better past few days!
I am quite interested which place in Italy did you get it exactly? Did you manage to get both frequencies (10967 and 10994)?
Best regards!
Alexander aka ttalex
Thanks to everybody
braluca
СообщениеДобавлено: Пн Ноя 05, 2007 14:18    Заголовок сообщения: Re: success Ответить с цитатой
Best regards!
Thanks to everybody
I watch both transponders.
Also Uzbekistan TV (but this I was able also before) and Space TV Azerbajan and radios.
I do not get Blu probably due to interference I have on roof, infact around that frequency also hotbird for me is banned
I live near Milan. What About you?
Poka
ttalex
СообщениеДобавлено: Пн Ноя 05, 2007 16:07    Заголовок сообщения: Re: success Ответить с цитатой
Great to hear that you watch both TPs! Smile
I live nearby Brussels. I have ChannelMaster 120 dish and also receive both TPs.
Poka
braluca
СообщениеДобавлено: Пн Ноя 05, 2007 23:24    Заголовок сообщения: Ответить с цитатой
for what i have understood channel master is the top dish one can have
