PAVLODAR Модератор
Добавлено: Пт Сен 30, 2005 9:33 Заголовок сообщения: |
| Цитата: | News of Digital + 27 of September Digital + will change the cards of some credited
Several weeks after the system Nagra utilizes mundoplus.tv by Digital + to codify s mundoplus.tv emissions by Hispasat was pirates mundoplus.tv, the platform moves puts on file and in brief will change the cards of alg mundoplus.tv credits you mundoplus.tv s that receive s mundoplus.tv emissions through the satellite one Hispasat
But in this occasion, as opposed to it ocurri mundoplus.tv previously, the change will not affect to to mundoplus.tv s credits them mundoplus.tv s, but the ones that will receive the new card will be something less than 30.000 person mundoplus.tv
In concrete they are these people the ones that currently have concrete model mundoplus.tv of card, that to mundoplus.tv that externally equals seem, internally they are different to mundoplus.tv that is distinguished them for having mundoplus.tv characteristic serial number.
This cards have great mundoplus.tv failure of security, what there is permiti mundoplus.tv that have if open mundoplus.tv by the pirates, and that the seen platform without paying utilizes mundoplus.tv or terminals free modifies mundoplus.tv s or programmable cards, for that reason being these cards the ones that be going to be s mundoplus.tv tituida mundoplus.tv
The change will be carried out in brief and between this week and the following one mundoplus.tv affects them s will receive the new card, that should activate siguie mundoplus.tv or mundoplus.tv you simple steps that are detailed in mundoplus.tv to letter that will receive j mundoplus.tv to with the card. The old cards to will stop being mundoplus.tv erativas in few weeks, depe mundoplus.tv ie mundoplus.tv or of the rhythm of arrival of the new and of possible incident mundoplus.tv |
| tigekala писал(а): | | Что это озночает PAVLODAR? |
Незнаю,30.000 что-то маловато,что с остальными делать будут  _________________
PAVLODAR Модератор
Добавлено: Вт Окт 04, 2005 15:38 Заголовок сообщения: |
Теперь знаю Вот на нем.яз. кто может переведите мужики,нет время,если,что завтра сам переведу
| Цитата: | Digital+ wird über Hispasat ca. 30.000 Karten der ROM101 auswechseln mit dem ROM 103. Dies soll in der nächsten Woche geschehen. Dann möchte man einen neuen IDEA Key, RSA Key und PK senden und die ROMs 110 und 103 updaten. Das ganze soll so übermittelt werden, das die Kartenserie mit den ROMs 101 dann zerstört werden, also ein "Selbstmord" geschieht. Dies ist nötig, damit die ROM 101 Kartenserie auf keinen Fall die neuen übermittelten MicroCodes preisgeben. Ob es aber wirklich funktionieren wird, weiss man selbst bei Kudelski nicht, denn so eine Aktion wurde noch nie gestartet.
Man darf gespannt sein, was so in ca. 2 Wochen passiert, wenn die neuen Karten ausgeliefert werden.
In den Undergroendforen gibt man sich gelassen und weisst darauf hin, das ja "nur" der ROM 101 Dump preisgegeben wurde, bis jetzt!
Es wird bald sehr spannend!
| Цитата: | Nur Cinemania 1, 2 und 3 sind noch in Seca 3, der Rest der Plattform ist in Nagra 2 auf Astra.Es sieht so aus, als ob sie schon in der Finalen Phase des Wechsels auf Astra sind. Fast alle Kanäle senden auf Simulcrypt Seca 3 und Nagra 2. Das bewirkt einen früheren Romwechsel und die "Dunkelphase" für Forennutzer ist sehr nahe.
Taquilla 9 auf Astra ist im Versuch von Nagra 2. Sie sind in der Probephase und Taquila ist in Simulcrypt. Nach den Tests aktivieren sie den Rest von Taquilla und lassen ECM Und EMM von Rom 101 auf Hispasat weg. Astra wird dann bereit sein, neue Abonenten auf Nagra 2 aufzunehmen.
Der 7. Oktber ist das Datum, die neuen Abokarten von D+ zu verteilen. Freitag, der 7. Oktober ist der Tag an dem D+ Gegenmaßnahmen ergreift und keine Reklamationen von den Abonnenten akzeptiert, weil an diesem Tag die neuen ECM und EMM aufgeschalten werden um die Piraten zu bremsen. Mindestens 70 % der betroffenen Abonnenten vom Rom 101 haben schon die neue Karte erhalten. Der Zeitrahmen hat sich erweitert, weil manche Abonnenten die neue Karte nicht erhalten haben, da sie nicht zu hause waren, als die Post kam. |
Добавлено: Вт Окт 04, 2005 16:49 Заголовок сообщения: |
| PAVLODAR писал(а): | | tigekala писал(а): | | Что это озночает PAVLODAR? | Теперь знаю... | Да это же с начало ясно было, что это озночает... и смайлики там были и
С начало подмигиваю, а потом грустно... |
PAVLODAR Модератор
Добавлено: Вт Окт 04, 2005 18:31 Заголовок сообщения: |
| tigekala писал(а): | | PAVLODAR писал(а): | | tigekala писал(а): | | Что это озночает PAVLODAR? | Теперь знаю... | Да это же с начало ясно было, что это озночает... и смайлики там были и
А что грустно то Не так всё и плохо,по крайнер мере для нас
перевод на первую ссылку...
| Цитата: | | D+ на Hispasat будет производить замену примерно 30. 000 карт с ROM101 на ROM103. Это должно произойти на следующей неделе. Затем будет послан новый ключ IDEA, новый RSA и PK , потом зделают апдэйт на ROM110 и ROM 103. Всё это делается для того что бы намеренно убить карты с ROM101. Будет ли это действительно работать Kudelski сам не знает так как,такую акцию ещё никогда не пробовали. |
на вторую вообще коротко...
| Цитата: | Сейчас на Астре только Cinemania 1, 2,3 в Seca 3,остальное всё Nagra 2 и ....................
Короче Д+ полностью готов для перехода на Астру....
70% подписчиков с картами Ром101,уже получили новые карты( ) последняя дата 7 Октября... |
apoyas
Зарегистрирован: 14.10.2004 Сообщения: 41 Откуда: Рига, Латвия
Добавлено: Чт Окт 06, 2005 11:59 Заголовок сообщения: |
| Это что значит, PAVLODAR? Digital+ уходит с Hispasat? |
blui
Добавлено: Чт Окт 06, 2005 13:02 Заголовок сообщения: |
| Да ничего там не уходит, они меняют 30 тыс карточек для владельцев EchostarPVR на Астре, так как там в спешном порядке месяц назад нагру2 отключили и оставили только кардмаггедон, а определённые записывающие функции этих ресиверов могли работать только через чистую нагру2 и их владельца месяц этими функциями пользоваться не могли. |
PAVLODAR Модератор
Добавлено: Чт Окт 06, 2005 21:13 Заголовок сообщения: |
| apoyas писал(а): | | Это что значит, PAVLODAR? Digital+ уходит с Hispasat? |
Если всё получится,как они задумали(моё мнение не попрёт),то можно ожидать ухода
| blui писал(а): | | Да ничего там не уходит, они меняют 30 тыс карточек для владельцев EchostarPVR на Астре, так как там в спешном порядке месяц назад нагру2 отключили и оставили только кардмаггедон, а определённые записывающие функции этих ресиверов могли работать только через чистую нагру2 и их владельца месяц этими функциями пользоваться не могли. |
Ага ,а если завтра смогут,то послезавтра опять отключат клоун. _________________
blui
Добавлено: Чт Окт 06, 2005 22:18 Заголовок сообщения: |
Ага ,а если завтра смогут,то послезавтра опять отключат клоун. |
Не понял, что ты этим хочешь сказать. Эта инфа пришла из Испании так что время рассудит. |
PAVLODAR Модератор
Добавлено: Чт Окт 06, 2005 22:33 Заголовок сообщения: |
| blui писал(а): | | PAVLODAR писал(а): |
По твоему,если с Испании ,то всё
А откуда,как ты думаешь у меня инфа,с Израеля что-ли
Я просто написАл,о чём сейчас на закрытых форумах базарят...
В одном ты прав,надо ждать ,моё личное мнение, Kudelski проиграл и уже давно,это уже просто шаги оправдания(может быть отчаяния),мол всё предприняли,что смогли  _________________
Andrs
Добавлено: Пт Окт 07, 2005 11:06 Заголовок сообщения: |
| Насколько я понял, они будут менять только те карточки, при помощи которых, по их мнению, Д+ легко взломать. У остальных абонентов карточки, видимо, куда надежнее. |
PAVLODAR Модератор
Добавлено: Пт Окт 07, 2005 23:35 Заголовок сообщения: |
| Andrs писал(а): | | Насколько я понял, они будут менять только те карточки, при помощи которых, по их мнению, Д+ легко взломать. У остальных абонентов карточки, видимо, куда надежнее. |
Ну ты сказанул,ты что вообще не читал что здесь постят
Если на Хиспе только 30.000 клиентов То извени
А надёжных карт на сегодня нет,поверь мне просто наслово  _________________
Добавлено: Сб Окт 08, 2005 7:37 Заголовок сообщения: |
| PAVLODAR писал(а): | А надёжных карт на сегодня нет,поверь мне просто наслово  | Одну карту знаю - Canal Digital (1W) conax CAS5/7 карта...
Но это не связано с Хиспасатом... |
